A/C vents blocked
Old Oct 18, 2022 | 06:18 PM
93xjs6cyl's Avatar
Default A/C vents blocked
I live in Arizona where it can get over 110 degrees in the summer. I bought my 1993 XJS 4.0 convertible about a couple of years ago. I noticed a receipt from a dealership that was for blocking the A/C. I can hear the fan going like crazy, but not a whole lot of air seems to be coming out. If possible I would like to undo whatever they did if possible. Has anyone ever heard of this being done before? If so, where should I look for the blockage?
Old Oct 19, 2022 | 08:06 AM
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old Oct 19, 2022 | 09:12 AM
ptjs1's Avatar
No idea what "blocking the aircon" means? Never heard of that, doesn't seem to make any sense.
The only thing someone might do if the aircon was broken / leaking and the owner didnt want to fix it, is to disonnect the compressor belt to save petrol.
Start from basics and diagnose what is working and not working. Read up on the system and understand how its supposed to operate. Check the basics. Is the compressor clutch engaging when the aircon button is turned on? Are the fans working at correct speeds? Is the heater control valve opening snd closing and varying the temperature?
Good luck
Paul
Old Oct 19, 2022 | 09:37 AM
jal1234's Avatar
It COULD be that they blocked the outlets to the rear vent on the console to force more air out of the front. There are two outlets running to the vent, one on each side of the front of the console under the ski slope. It's somewhat common to block those outlets.
However, that doesn't explain why not much air is coming out of the front. With the fans going full blast and the a/c on full cold, does a lot of air come out of the defrost vents at the base of the windshield, and little air out of the center vents? If so, something is stuck or wrong with the defrost vent vacuum circuit, as they must close for the center vents to open. They are mechanically interlinked. If the defrost vents cannot close, the center vents will never open. Both vents are controlled by vacuum actuators on the right side of the hvac unit. The actuators are themselves controlled by solenoids.
Jon
taperguy
Dec 30, 2021 05:08 PM
stran0020
Apr 22, 2020 01:36 AM
Jbaker229
Sep 23, 2019 11:32 AM
Kariblay
Aug 31, 2018 04:20 AM
flor
May 6, 2013 04:08 AM
