cam cover gasket sealant
Old Mar 18, 2014 | 05:14 PM
azblindguy's Avatar
Default cam cover gasket sealant
hello everyone, finally started the cam cover gasket and half moon replacement. Was wondering if I needed to use a gasket maker/sealant on the cam covers and half moons. The cam cover gaskets I order I believe are the Gortex ones, looks like a piece of thin sandwiched between two rubbery pieces, and using the alum half moons. Also thought I read somewhere to use new cam cover bolts?
Old Mar 18, 2014 | 07:16 PM
Doug's Avatar
I don't use any sealant with the Gortex gaskets. I do use a decent smear of Permatex #2 on the half moons.
I've never used new bolts and have had no problems, personally.
Others will chime in with their own experiences.
Old Mar 18, 2014 | 08:06 PM
Ezrider's Avatar
im just assuming your v-12 but i recently did my valve cover gasket on my 4.0 i used a little permitex on the half moons nothing on the cover gasket and its dry as a bone now.
Old Mar 18, 2014 | 09:17 PM
Bill C's Avatar
The cam cover, was supposed to be my winter project but it's just too cold in the garage to get anything done so far. But I have been reading up on it in preparation. On page 62 of "the book", Kirby talks all about the cover bolts. However, Doug has the real experience, all I've done is read about it.
Question for Doug though (if you don't mind a bit of a hijack). Did you have to go in afterwards and re-tighten the bolts, or did you use some kind of locking washers or Loctite?
Old Mar 18, 2014 | 10:14 PM
Doug's Avatar
Now you're really taxing my memory :-)
I think I might've used those 'internal tooth' type lockwashers. Or maybe that's what the original bolts are fitted with? I can't remember for sure. But I do know I never went back and re-tightened.
Boeingtravel95
Sep 14, 2015 05:01 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 09:10 AM
1964Daimler
Sep 9, 2015 11:20 AM
jaggermang
Sep 8, 2015 07:07 PM
