Can't turn over rear end
Old Jul 19, 2014 | 03:59 PM
86jag's Avatar
Default Can't turn over rear end
My rear end is seize up, I believe it is just the rear brakes stuck to the pads. The car has been in my garage for 2 years. I tried to use a breaker bar on a lug nut with it jacked up. But I didn't want to break anything so i quit. Took me forever today just to get the rear wheels off. I need to turn over the rear so i can remove the driveshaft. I am shortining the driveshaft for my 6.0 v12 w/ 4l80e trans conversion. Any suggestions? The next thing i think i might do is just remove the brake pads.
Thanks in advance!
-Scott
Old Jul 19, 2014 | 04:27 PM
calvindoesntknow's Avatar
Absolutely no movement? Because it could be the rubber line is broken down on the inside and caused a pressure lock. I've seen this happen on the front brakes of late model fords.
Old Jul 19, 2014 | 07:26 PM
86jag's Avatar
On the driveshaft I get a little bit of movement going into the diff, but at the wheels they won't budge at all. They moved 2 years ago when I rolled the car into my garage. I will update tomorrow as I am done working on the car today. Before that the car sat in another garage since 2003 due to its overheated motor.
Old Jul 19, 2014 | 11:14 PM
I am thinking park brake pads have rusted and jammed to the rotors.
That is if the car had the park brake applied for 2 years. Makes sense more so than the main pads.
Old Jul 20, 2014 | 03:25 AM
superchargedtr6's Avatar
I had one caliper seized, and had the same problem. But I could drive the car. But it overheated the pads so bad smoke started coming out after a few hundred yards.
Old Jul 20, 2014 | 04:01 AM
Brake buster's Avatar
have you taken off the ' hand brake ' or parking brake as you may call it
as the handle is an auto collapsing handle, and needs pulling up to release the brake
just a thought
BB
Old Jul 21, 2014 | 08:27 PM
86jag's Avatar
@Brake buster
You figured it out, I feel like a complete idiot. I thought I had released it but I didn't press hard enough on the parking brake release button. Well in the meantime I have determined my rear brake calipers are not road worthy. One of the rubber boot seals has completed dry rotted to crumbles.
Thanks again for pointing out what should have been the obvious.
JarodL
Mar 7, 2024 01:39 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
obwoodie
Sep 3, 2015 07:45 PM
Busa R
Sep 3, 2015 05:01 PM
King Charles
Sep 3, 2015 12:40 AM
