Car not starting
Old Jun 22, 2020 | 04:40 PM
Arhabb II's Avatar
Default Car not starting
Hello friends,
I'm having a bit of trouble getting the car started after putting the transmission back in and replacing the starter. The car would not crank at all so i'm thinking it has something to do with the starter wiring. In the process of putting the starter back in I do remember seeing two larger gauge wires that confused me, i bolted both to the solenoid and the terminal to the terminal post. I thought this was the correct configuration but now I am not sure, its been a month since I first removed everything. Can anybody help with this?
1990 Jaguar XJS V12(5.3)
Old Jun 22, 2020 | 06:19 PM
orangeblossom's Avatar
Hi Arhabb 11
You may have disturbed the Fuseable Link on the Battery
Push those Connections Together and She should Crank unless the problem is around the Starter or the Gear Shift Area but only you would know that
Old Jun 23, 2020 | 12:28 AM
VancouverXJ6's Avatar
Yes that stupid cable causes all sorts of bs
Old Jun 23, 2020 | 05:48 AM
XjsBanger's Avatar
Check the gear selector and selector's switch, maybe it's not in parked position
Old Jun 23, 2020 | 07:07 AM
carsnplanes's Avatar
Somebody had a recent thread about non starting on a V12. I offered a work around to isolate where the loss of start control might be or loss of main 12V direct power might be. Diagram shows the two large cables on the starter. One from the battery, and the other goes to the alternator. The 3rd smaller wire is the start control to energize the solenoid on the starter. See this diagram below to help. Th temporary ground I show is to isolate out the saftey and security interlocks.
jnporcello
Apr 22, 2015 04:04 PM
Fesiwig
Feb 4, 2015 02:11 PM
dinerdash
May 15, 2013 07:30 PM
Pura Vida
Jan 16, 2012 03:42 PM
maikal_0011
Nov 5, 2011 11:18 AM
