Carpeting
Old Oct 16, 2021 | 07:04 PM
Pendax7's Avatar
Default Carpeting
I'm not sure if i'm missing something or if it was not installed or replaced.
I lifted the floor mats to dump the dirt out but below the floor mat was a foam lining then metal.
Am I just missing carpet or did the car doesn't come equip with it.
Just curious.
Old Oct 16, 2021 | 07:25 PM
garethashenden's Avatar
I’m not sure, but for what it’s worth mine is the same. Floor mat, foam, metal floor.
Old Oct 17, 2021 | 05:16 AM
ptjs1's Avatar
Pendax7,
The XJS carpeting is made up of fixed carpet around the sills, transmission tunnel, under seats and rear footwell bulkhead. It then uses removable sections of carpet for the front and rear footwells, which clip into place by differing systems, depending on the age of the XJS. In the UK, we refer to these as the footwell carpets. You can then buy what we call "carpet mats" which are protective carpet overmats that go onto top of these carpet pieces. I'd suggest you always buy some version of those to protect the base footwell carpets.
So, your car, is standard as regards its carpet.
Paul
Old Oct 18, 2021 | 11:20 AM
XK8XJS's Avatar
Recommendations regarding sourcing of replacement carpet set for the XJS?
Old Oct 18, 2021 | 12:06 PM
Vee's Avatar
Vee
Search this forum with "Carpet replace" and you should find what you need. There's a few options depending on your needs and budget.
Thorsen
Sep 16, 2021 03:39 PM
Ceckman
May 19, 2019 08:36 PM
hen555
Jun 14, 2015 04:28 PM
mlewisfwa
May 4, 2008 03:14 PM
