CEI Ignition Coil
DAC6093 is the usual single coil replacement for the original two coil arrangement as used on the Lucas ignition cars. I don't know Lucas number for the DAC6093, if there is one.
The Lucas DLB170 replaces the 35C6
Over here I used the FuelMiser CC215. Rated as a "Universal Electronic Ignition Coil", and sits at about 0.7Ohms +/-.
No issues with starting cold or hot, or reaching Redline if and when required.
Basically any Electronic Spec Ignition Coil will work just fine. Just ensure the Primary Ohms are around the 0.6 mark and no more than 1.0 Max.
Stay away from those Bosch T Coils, if they still make them??, I think not, as they cannot handle the heat on the V.
