check engine light fails smog test
Old Feb 8, 2023 | 03:45 PM
jagx94's Avatar
Default check engine light fails smog test
my check engine light on my 94 xjs 4.0 lamps at start up but not every time when you turn the ignition key. failed California smog test as it has to lamp every time ignition is turned before start. I was told I could clean contacts. where is the electrical dash warning light module in the 94 xjs hardtop?
Old Feb 8, 2023 | 04:13 PM
equiprx's Avatar
My 94 failed CA SMOG for no check engine light.
It needed a replacement lamp that was really difficult to find.
They are a Bayonet Type (I think I may have a few).
Does only the CE light fail to light?
Might be a faulty ground if more than one fails.
Old Feb 9, 2023 | 09:37 AM
jagx94's Avatar
thank you, the bulb is working but intermittently. When I wait five minutes it does appear at turning the key to position before start. just not every time. So, it fails the test sequence at smog center. pretty stupid as it has new cats and passes emissions test.
Old Feb 10, 2023 | 03:42 PM
Brewtech's Avatar
Tell em the car has two CELs. The dash light and the notification that pops up on trip computer. I managed to circumvent that by simply guiding the tech to look at the screen vs the dash. Hope it works for ya.
Old Feb 13, 2023 | 10:17 AM
Dleit53's Avatar
I have seen other vehicles that would not light the check engine light until the ECU had time to shut down. It may be normal for the light to be off if the key is switched off then switched right back on. However, 5 minutes seems to be excessively long. Is there any aftermarket electrical equipment on the car that may contain capacitors that could be keeping the ECU awake longer than normal?
Old Feb 14, 2023 | 01:00 PM
jagx94's Avatar
Hey, you are correct sir. I took my xjs to a great jag mechanic in Marin County calif. he backs up what you suggest. after timing it its not five minutes but much shorter. I have no after market add ons that would bring capacitors into the mix. he sent me to a smog shop more familiar with jags and system passed, thanks for your help!
SpartanBadger
Nov 16, 2021 08:37 AM
SUCHARD
Apr 9, 2021 12:07 PM
baloozman
Sep 30, 2020 09:02 AM
papalarge57
Apr 21, 2016 10:59 PM
XK8Guy
Apr 16, 2008 11:51 AM
