Coolant Flush
Old Nov 14, 2012 | 10:11 AM
maxx470's Avatar
Default Coolant Flush
Hi,
On the 6.0 litre whats the easiest way to go about flushing the cooling system ?.
Is it necessary or will a drain down and new antifreeze mixture do ?.
There are no problems with it at present but I want to keep it that way.
Old Nov 14, 2012 | 02:25 PM
meeither's Avatar
I believe there are 2 caps (Radiator and Expansion tank) as on the 5.3's and if so you can use an off the shelf flush kit (Advance Auto/ Auto Zone) and accomplish a nearly complete flush by opening both caps and using the other as a flush port. Apply some vacuum to your heater valve with a vacuum gun to open the heater valve ( most parts house's sell them if you don't have one) and flush your heater core while you are at it.
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
vwbusbits
Oct 13, 2015 03:43 AM
