Coolant level light question
Old Mar 22, 2022 | 07:24 PM
Sardonicus's Avatar
Default Coolant level light question
So I finally got the coolant system closed up. Did a bunch of work, flushed things out best I could, new water pump, efan conversion. Lots of fun, glad to have it done, but now that I have refilled the coolant the low level indicator light is on all the time. Now its entirely possible if there is something that can be unplugged that I unplugged it and forgot all about it, but im not sure where the sensor is. Would appreciate some advice on where to start looking to work out this issue.
Old Mar 22, 2022 | 07:28 PM
jal1234's Avatar
It's on the side of the coolant header tank on the left side of the engine. There is a single spade connector on the wire that connects to it..
Old Mar 22, 2022 | 07:32 PM
Sardonicus's Avatar
Thank you, I found the spade on the tank, but no wire. Can you tell me where abouts the wire originates so that I might track it down.
Old Mar 22, 2022 | 07:54 PM
jal1234's Avatar
It's a white/red wire that appears to come out of the bottom of the plastic relay cover immediately in front of the tank.
Old Mar 22, 2022 | 08:15 PM
Sardonicus's Avatar
Thank you, I had a quick look with a flash light, couldn't find it. Will try again tomorrow with better light.
Rhett
Oct 25, 2021 05:07 AM
thunderwood
Oct 22, 2021 09:39 AM
SamtheSham
Jul 20, 2021 06:58 AM
vdpnyc
Oct 3, 2016 02:29 AM
mosesbotbol
Sep 8, 2010 11:18 AM
