Coolent flush
Old Nov 24, 2017 | 08:50 PM
jordanmc's Avatar
Default Coolent flush
Hi,
trying to do a flush on my 92 but I can’t find the drain plug. Do you need to remove the spoiler to access everything?
Old Nov 24, 2017 | 09:25 PM
Doug's Avatar
It probably doesn't have one. Of my 5 Jags only 1 had a radiator drain plug...the 1995 XJR.
Old Nov 25, 2017 | 04:21 AM
Mark SF's Avatar
My 86 has a sort of faucet, on the right rear of the radiator. The valve is at the bottom, but a metal rod extends upwards, that turns the valve, and can be reached from above.
Wish I'd noticed it before sucking all the coolant out through the banjo bolt hole, with my mityvac. That was very effective though, and no mess.
Old Nov 25, 2017 | 05:59 AM
orangeblossom's Avatar
Hi Jordan
I usually take the Bottom Hose off the Radiator, which is about as easy as trying to Climb Mount Everest in a pair of Carpet Slippers.
A lot depends on how easy it is to undo the Jubilee Clip on the Bottom Hose, then having done so Twist the Hose in order to break the seal.
Which you can do with an Oil Filter Strap Wrench Remover.
But if you're going to replace that Hose, then just cut it through with a Bread Knife.
Very seldom any need to remove the Spoiler, providing that you have 'The Jaguar Gods' on your side.
Together with Sticking Plasters and the obligatory bottle of JD.
Home made Rad Hose Wrangler to Twist the Bottom Hose to break the Seal, which works on the 'Dutch Windlass' principle, or you could do it properly and use an Oil Filter Strap removal Wrench.
This is the sort of thing I use to undo the Jubilee Clip on the Bottom Hose
Undoing the Jubilee Clip on the Bottom Hose with the long extension Wrench shown in the previous pic.
Flushing out the Rad before Refilling
Blue Antifreeze mixed 50/50 with Deionized Water (How decadent is that!) but I live in a Hard Water Area, so only the best for my Baby.
Putting in the last drop of Antifreeze with a Syringe but with the benefit of Hindsight, I should have done it through the Banjo on the other side. (Although of course there are other ways)
Nothing more Satisfying than Flushing out the Rad (Note to Self I need to get out more)
Old Nov 25, 2017 | 12:00 PM
jordanmc's Avatar
Default Many thx
I will take another look tonight. I get pretty far under last night and it appeared that the rad was completely covered by the spoiler.
Old Nov 28, 2017 | 04:48 PM
jordanmc's Avatar
Default Why does this say
do not drain
Old Nov 28, 2017 | 04:53 PM
Mark SF's Avatar
I think they don't want it doing down the drain, as it is toxic.
