Could I leave the Engine Running while I Bleed the Brakes on my 4.0L AJ16
Old Sep 15, 2024 | 05:18 PM
orangeblossom's Avatar
Default Could I leave the Engine Running while I Bleed the Brakes on my 4.0L AJ16
Hi Guys
Having unsuccessfully tried to Bleed the Brakes on my 1995 XJS 4.0L with AJ16 Engine
I'm thinking that the problem could be Air Trapped inside the ABS which was completely drained when Fitting New Calipers
From what I've been reading and looking at on YouTube, it seems that Shops use a Special OBD Device to excite the Motor in the ABS while the ABS System is being Bled
Everything is OK until you Start the Engine, at which point the Pedal goes to the Floor (Lots of Guys on YouTube having the very same problem)
So thinking a little bit out of the Box, I was wondering if I should try Bleeding the Brakes with the Engine Running
Or do you think this sounds like a Bad Idea?
Old Sep 16, 2024 | 04:40 AM
Greg in France's Avatar
Alex
A bad idea. Go to your guy and get it done properly!
sanchez
Apr 28, 2024 02:33 AM
Jag!55pp
May 23, 2023 06:46 PM
8bit
Mar 30, 2022 07:51 AM
CZSteve
Aug 13, 2019 10:08 PM
orangeblossom
Jul 16, 2018 10:23 AM
