Couple mystery parts, '88 XJS
Old Dec 1, 2024 | 05:36 PM
AZDoug's Avatar
Default Couple mystery parts, '88 XJS
Behind the grill and in front of the radiator/AC condenser is something labeled Auxiliary Coil. With only two primary wires to it, no high voltage OUT wire. What is this for? Is it now superfluous and can be removed permanently?
Behind that coil, there is a large two pin electrical connector, unplugged, one end goes to a flat metal disk about 3/8" diameter, looks like a sensor of some sort riveted to the flat panel that the coil is mounted to. What is that?
Question on lower grill: I see only two screws holding it, one on each side, is it also attached to the lower center valence exterior panel with rivets?
Thanks,
Doug
Old Dec 1, 2024 | 08:46 PM
Doug's Avatar
The secondary coil was for for the ignition. The original-spec primary coil couldn't do the job alone after 3500 rpm or so.
The common thing is to replace the original primary coil with something modern (usually a DAC6093) and abandon the secondary coil.
The sensor thingy is for the heated windshield washers. Below XXX-degrees the heaters are turned on
Old Dec 3, 2024 | 08:53 AM
RGK20m3's Avatar
No rivets on lower grill, pegs that fit into holes.
Old Dec 3, 2024 | 09:38 PM
AZDoug's Avatar
Got it off, it was just glued down really well from a long ago respray.
Off tomorrow to the powder coaters for sand blast and satin black powder coat.
Thanks,
Doug
hueyhoolihan
25
Aug 4, 2024 07:13 PM
Rob wilson
Nov 12, 2019 07:45 PM
mikeburg
Jul 8, 2015 08:08 PM
Mjoseph420
Jan 16, 2015 09:16 AM
schroeterkurt
Dec 30, 2008 05:39 PM
