Cruise control solenoid question
Old Apr 28, 2021 | 09:20 PM
exjayess's Avatar
Default Cruise control solenoid question
Hello everyone. I’m finally getting around to sorting out the cruise control on my 1991 XJ-S (Marelli).
The cruise control components were in a box until I recently began to install them. I have repaired the bellows with silicone sealant and now have what appears to be a good seal, fingers crossed.
The question I have is: where does the blue solenoid
EAC 7905 bolt onto the engine? I don’t think it is in the same place as pre-Marelli cars. It is probably near the A bank, but it is not obvious.
Thanks for any replies.
Old Apr 28, 2021 | 09:34 PM
baxtor's Avatar
l assume you mean the dump valve. Mine is mounted just to the front of A bank manifold in the area just below the A bank fuel regulator.
That's on a 1989.
Old Apr 29, 2021 | 07:26 AM
exjayess's Avatar
Thanks Baxtor. I'll have another look for a bolt in that area. Yes, I guess it is referred to as a dump valve.
Old Apr 29, 2021 | 09:22 AM
EvertXJS's Avatar
On my '86 EAC 7905 is the 3-way control valve that is used to connect vacuum to the cruise control bellow with cruise control on and connect bellows to atmospher (dump) when off. It is fitted on the (M8 ?) studd that holds the air-cleaner on the right hand cylinder bank.
Old Apr 29, 2021 | 12:05 PM
exjayess's Avatar
Thanks EvertXJS. Much appreciated.
Choppa
Sep 21, 2019 02:13 AM
East Haddam
May 23, 2014 09:31 AM
Davexjrv8
Nov 29, 2011 09:38 AM
dutch
Aug 8, 2010 03:12 PM
