Delenair MKIII issues
Old Dec 27, 2020 | 04:24 PM
Morgan0616's Avatar
Default Delenair MKIII issues
Hello all,
I know this seems to be a widely covered topic, but I have a 1989 V12 XJ-S that is suffering vacuum issues to the climate control system. I know I have a lack of vacuum to the system as I have replaced the engine and never properly got the climate control vacuum supply correctly installed. I was hopping if anyone knew what color the original line is that supplies vacuum to the system. I have a few lines near the brake servo in the engine compartment that seem to be candidates. Yellow/black striped?
Anyways I have recently rebuild the heater core and it works fine, but all vents are not opening. I do have the 3 fan speeds.
Thank you all and I will supply photos later.
Old Dec 27, 2020 | 05:02 PM
Jagboi64's Avatar
Probably everything you need to know is here.
File Type: pdf
Old Dec 27, 2020 | 07:37 PM
Morgan0616's Avatar
Thank you very much! This will fix my issues!
Dean
V12_daimler88
Apr 19, 2020 01:53 PM
J_C_R
Jun 12, 2018 11:49 AM
Mike Beda
Oct 15, 2015 08:13 PM
kennith13
Sep 2, 2015 01:55 PM
fall4it
XJ40 ( XJ81 )
Sep 13, 2009 03:13 AM
