Differential Identification
Old Dec 20, 2023 | 01:06 PM
youngd's Avatar
Default Differential Identification
Tags attached to cover
Number on Differential
Numbers on Ring
Been working on the restoration of my 1988 Jag XJS and am trying to identify what differential is in the car. The previous owner provided a receipt for a differential rebuild with new 3:54:1 ring and pinion. I am attaching photos of the differential housing, tags that were bolted to the differential cover and numbers found on the ring gear. How do I know what I have?
Old Dec 20, 2023 | 01:57 PM
ptjs1's Avatar
youngd,
I can't give you any info on the numbers stamped on the Dana ring. But the numbers in teh tags are as follows:
PL = Powerlok - therefore a Limited Slip Diff
CBC1792 is the Jaguar part number for the early HE-era diffs. The actual numbers are CBC179228 for the 2.88:1 fitted in the 5.3 model. And CBC179235 for 3.54:1 fitted to the 3.6 model
46 13 = the Diff ratio, being 46/13 = 3.54
Paul
Old Dec 20, 2023 | 02:15 PM
youngd's Avatar
Originally Posted by ptjs1
youngd,
Paul
Thanks Paul. Much appreciated!
Old Dec 21, 2023 | 09:42 AM
DaveAllen's Avatar
You could confirm the crown and pinion correspond to the 46/13 by counting the gear teeth (13 on pinion, 46 on the crown wheel.. Alternatively, if the pinion gear isn't visible, count how many rotations of the input pinion are required to make one complete rotation of the output shafts.
HTH, Dave
Old Feb 5, 2024 | 08:49 AM
Youngd59's Avatar
Need a little more help here. I am trying to identify the correct output shaft seal for my differential. In the attached photo the green seal (next to the seal from my unit) is the one I received from SNG Barrett but as you can see it doesn’t match the one from my unit. I have attached a photos of my output shaft and bearing. I know the previous owner swapped differentials for a 3.54 but I don’t know what series it is. Hence I think I ordered the wrong parts. Can someone point me in the right direction?
Many thanks!
Old Feb 5, 2024 | 09:01 AM
ptjs1's Avatar
What part number did you order / did they supply for those seals? On the 3.54 diff fitted to facelift XJS, there's a changepoint when they moved to outboard brakes. I'm guessing you're still running inboard discs? I wonder if you've ordered / they've supplied the later seals?
Paul
Old Feb 5, 2024 | 09:54 AM
youngd's Avatar
Paul,
I have inboard brakes and I ordered part number JLM1264 for the differential output shaft seal and part number RTC1340 for the differential output shaft O ring. I should mention that the replacement O ring is not as thick and the one removed from my differential. Hope this helps.
ilikeike222
Jan 26, 2022 07:05 PM
MK2 1962
Nov 12, 2021 07:58 AM
PsiFox
Aug 11, 2017 12:40 AM
Arne
Sep 15, 2015 02:47 PM
polexj-s
Oct 28, 2012 05:04 AM
