Do relay colors mean anything
Old May 26, 2014 | 11:37 PM
Bc xj's Avatar
Default Do relay colors mean anything
In my 89 xjs convertible all the relays are different colors? is this for a reason ? Is there a color code sheet?
Old May 27, 2014 | 07:20 AM
sidescrollin's Avatar
from my experience relays are just whatever color the manufacturer decides on. I've replaced reds,blue ones, white ones, green ones, and even clear ones that all got replaced by a standard looking black box. All that matters is whats on the inside
Old May 27, 2014 | 07:55 AM
Doug's Avatar
On an '89 I don't think the relay color is significant. As Sidescrollin' says, it's what's inside that counts. Virtually all have a diagram showing the circuit .
Jaguar threw in a few oddballs with diodes that should not be replaced with a generic relay. On the 80s vintage Jags the relays with diodes were identified by a diagonal stripe painted on the case.
Also, be particularly aware the Jaguar used many relays with a 30-85-86-87-87 terminal configuration. In most cases these can not be replaced by a relay with the much more common 30-85-86-87-87A configuration.
All that being said.....
I strongly suspect that some of the different colored relays you're seeing are not relays at all. Jaguar often used timers and diode packs that look just like a relay and even used typical relay-type sockets/connectors...but they most assuredly are not a relay. I've seen these in red, blue, yellow, green.
On later Jags I'm pretty sure the relay color IS significant....but that's a diffferent discussion.
Old May 31, 2014 | 06:56 PM
mghirsch's Avatar
Doug is half right. The insides is what counts, but the color is a way Jaguar identifies the relays. i.e blue/white is one for the starter relay.
Old May 31, 2014 | 08:18 PM
Doug's Avatar
Well, actually, I DID say that color was probably signifcant on later models but not on the '89
It wasn't as much later as I thought, though. In reviewing various tech publications I see frequent reference to relay color for 1990 models, but none at all for 1989 models.
<shrug>
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
asleach2889
Oct 1, 2015 01:53 AM
kevinl
Sep 24, 2015 08:25 PM
