Dreaded shielded wire Hello Grant!
Old Nov 6, 2016 | 03:21 PM
  #101
warrjon's Avatar
I have metered the wire to pin 24 on the Marelli and Bax is correct
Edit as I was wrong
Old Nov 6, 2016 | 03:26 PM
  #102
Doug's Avatar
Originally Posted by warrjon
I still think you'll find its the tacho wire.
Bax does your car start with this wire disconnected. My car is still in bits ATM.
If it's solid white and shielded, it's the wire to the ECU....lower left area of your diagram...which has been cut off.
If it's white/slate/blue, it's for the tachometer
In the original pic of the wire you can *just* see the braided shielding peeking out of the sheathing. or...um...I think you can !
Old Nov 6, 2016 | 03:45 PM
  #103
warrjon's Avatar
Mine was way in bottom of the V almost invisible there is not enough wire to tie mine to the fuel rail.
So in the Marelli the dreaded white wire does go through the engine bay, at least in early Marelli cars.
514Jag
Apr 1, 2017 10:07 PM
1964Daimler
Aug 6, 2016 05:51 PM
Rivn8r64
Aug 5, 2016 04:45 AM
Keegan Canida
Jul 30, 2016 08:59 AM
Ducmon
Jul 14, 2016 01:37 PM
