EGR Fault ("Check Engine" Warning) - 1994 XJS
Old Apr 26, 2015 | 12:28 PM
Stuart1960's Avatar
Default EGR Fault ("Check Engine" Warning) - 1994 XJS
The engine warning for the EGR Is on. For anyone who has experienced this, is it possible to clean the valve, or is it likely to need replacing. How easy is it to get at and remove?
Old Apr 27, 2015 | 08:01 PM
Vee's Avatar
Vee
Very easy to get at. Just buy a new one. It will run you $100.
I was never successful at cleaning my EGR out and having permanently fixed the problem.
I also don't believe the aftermarket product will be any less effective than the OEM. Get the least expensive product you can get.
Two simple bolts hold it in place. Make sure to buy the gasket if the EGR brand you buy doesn't come with it.
Old Apr 27, 2015 | 08:03 PM
Vee's Avatar
Vee
Here is a pic that should show you approximately where your valve is. (The AJ6 shouldn't be too much different.)
Old May 1, 2015 | 10:28 PM
Stuart1960's Avatar
Default Egr
Thanks for the info. I found the valve and have ordered the replacement.
Old Aug 9, 2015 | 07:55 AM
Stuart1960's Avatar
Just for feedback on this - I fitted the valve, but couldn't get the warning message to clear. Finally after searching through forums, realized that the only reset option was to disconnect the battery. Did this, message reset, and it's been fine since. Thanks to those who provided information that helped me sort this.
Old Jul 28, 2016 | 08:00 AM
dtony's Avatar
Hi there Stuart,
Where did you buy your new valve??
Tony in NM
D.K
Dec 10, 2023 02:05 AM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
