Engine surge from 1000 rpms to 1700 rpms right before it warms up
Old Apr 1, 2009 | 08:39 PM
Doug's Avatar
Its the "AAV" (aux air valve) that you took off and cleaned. Good that it is clean, but is is working ? Or leaking?
In any case, I'm 99% sure you've go "extra air" coming in from somewhere. This increases the idle until the fuel shut off kicks in, at which point in drops down....then picks up gain, then cuts off, then.......then....then....
Are your throttles gapped at .002" and the linkages sync'd?
Throttle body bolts tight?
You have just the one kickdown switch. Is your kickdown not working? If its dead, I have some suggestions that might help
dsnyder586
Dec 29, 2024 07:39 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
