erratic Start
Old Mar 24, 2018 | 09:25 AM
jordanmc's Avatar
Default erratic Start
Hi everyone,
So I am having trouble with my 92 xjs v12.
last year every so often the starter would not crank and a simple wiggle of the shifter sorted it. It seems to have gotten worse. I have dug through old posts and believe the starting course of action is.
1) on the passenger side in the engine compartment unscrew the plastic cover to access the starter relay. Clean connections
2) follow that line down to the spade connector. Clean connections
3) check for a loose ground around that spade connector
4) check the switch in the shifter to align it. Here is where I am lost. I have pulled off each of the 4 connections and the car seems to start. I assumed if I pulled one off and left 3 for instance the starter would not engage. Does anyone have any clarity around what the 4 connections are. In my manual it only shows an earlier car with 2 connectors. Is there anything else I should check re this problem?
I am attaching a pic
Thanks!!
Old Mar 24, 2018 | 09:37 AM
Doug's Avatar
I don't have a '92 diagram but....
The black and black/green wire typically pertain to the neutral safety switch and starter circuit....typically by providing a ground to a relay. I don't know, off hand, what the yellow/red wires are for....possibly a tie-in to cruise control function.
Hopefully someone with a 1992 wiring diagram will chime in.
Old Mar 24, 2018 | 11:39 AM
JagCad's Avatar
Me either. But, the "wiggle the shifter" is a sure clue that something is
amiss in the neutral/start circuit. connectors, wires or the switch itself.
Carl
Old Mar 26, 2018 | 07:22 PM
jordanmc's Avatar
Default no luck
Still can't make heads or tails of how to adjust the switch. Not even sure that is the issue. Sometimes moving the shifter back and forth a few times will do the trick and the starter will crank. Does anyone know the procedure on how to check the switch and adjust.
Old Mar 27, 2018 | 12:20 AM
Doug's Avatar
Just loosen the tiny screw and the switch will pivot for adjustment
With the gearshift comfortably in "P"...not intentionally forced all the way forward to the last millimeter....and the switch loosened, hold the key to the 'start' position then carefully move the switch a tiny bit in either direction until the starter engages. Do this a couple times; you'll find a sweet spot in the adjustment range of the switch where it will consistently close the circuit.
I'm talking about the switch with the black and black/green wires
Britrover
Dec 17, 2014 04:40 PM
johndahlheimer
Sep 11, 2014 03:27 PM
Xcellr8
May 5, 2011 01:36 PM
pdog2000
Sep 10, 2010 12:26 AM
Mr T
Nov 22, 2008 08:19 AM
