exhaust issue
Old Jan 2, 2019 | 04:48 AM
Shahar Alon's Avatar
Default exhaust issue
hey all
is there any way to assemly the exhaust without removing parts from rear cage ?
Old Jan 2, 2019 | 06:38 AM
I have never removed any other item/s from the rear cage to remove and/or replace that twisted pipe.
Easy, NO WAY.
Lining up the top mounting pin in the rubber bush can test ones sense of humour.
Usually with the car raised, a long way, and the wheels "hanging" the task is simple enough if you are NOT in a hurry.
Old Jan 2, 2019 | 06:53 AM
Easy, NO WAY.
my cage is now out of the ar anf i still having trouble insert the de** pipe
Old Jan 2, 2019 | 01:07 PM
brinny's Avatar
Do you have the 3 holeflange loose on the pipe. You have too slip some of the pipe through the cage and move the flange along after it’s through.
Old Jan 2, 2019 | 01:11 PM
try that but no luck there.
Old Jan 2, 2019 | 02:18 PM
brinny's Avatar
Persevere. Not too difficult.
xjrwithproblems
Aug 10, 2019 07:30 AM
jagxkrtoofast
Sep 29, 2014 07:43 PM
DJ99
May 24, 2012 08:10 PM
gragner66
Sights N Sounds
Oct 14, 2011 07:04 PM
SeldomJAG
Oct 11, 2011 12:21 PM
