I need to replace this expansion tank on my 1994
XJS V12, where can I find one? I have attached a photo of a similar one I will most likely need to flush my coolant system. It's been over 2 years but only drove the car 500 miles during that time.
Thank you
If you dont want the one from Barratts, check the marketplace. As I recall there were a couple of xjs for parts recently..... You can try searching that part number too, just to see what is listed.
Thank you
not sure what part of the world you are in but ime in the U.K but I got a stainless steel one from somwhare in australia I found on Google. It is an excellent product
Hi rgp, do you have a link to the supplier?
I refurbed mine the best I could, but would prefer to replace with stainless.
@jerry_hoback you mentioned Barratts, is there anything wrong with the item they are selling?
Do you know the difference between an OEM Jaguar one and a reproduction one? I would like to keep the car as original-looking as possible.
Also what other parts do you suggest I should replace while installing a newer Expansion tank?
