fault codes... tables?
Old Nov 5, 2014 | 11:48 AM
Jonathan-W's Avatar
Default fault codes... tables?
Does any one have the Fault code table for the 1992 XJS v12
I am get a FF 13
it showed up after I had a dead bank B
which I fixed with in 5 minutes...
she runs ok now...
Old Nov 5, 2014 | 01:07 PM
sidescrollin's Avatar
the jaguar FF system isn't too specific. In OBDII systems 13 is generally a misfire and then it will have two more numbers following it to be more specific. Without finding a guide FF13 pretty much means you have/had a ignition problem or misfire.
Old Nov 5, 2014 | 05:29 PM
Jonathan-W's Avatar
Default codes
they are listed in the XJS owners hand book starting on page 308
I will make a list of them tonight and post them here...
Old Nov 6, 2014 | 12:29 AM
I was going to say I would think they would be in the owners manual, but sort of doubted it since there is little info online. Maybe that is why, because everyone that needs it has it?
Old Nov 6, 2014 | 10:24 PM
Jonathan-W's Avatar
Fault code Description Function
11 Idel pot or associated wiring Looks for idle trimpot out of normal operating range.
13 Pressure sensor Checks for manifold pressure difference and engine cranking
and engine running.
14 Coolant thermistor or associated wiring. Looks for coolant thermistor static during engine warm up.
16 Air thermistor or associated wiring. Looks for air thermistor resistance out of range.
17 Throttle pot or associated wiring. Looks for throttle pot resistance out of range.
18 Throttle pot/airflow meter calibration. Looks for low throttle pot siginal at high airflow.
19 Throttle pot/airflow meter calibration. Looks for high throttle pot siginal at low airflow.
23 Fuel supply. Looks for poor feedback control in rich direction.
29 ECU self check. Checks microprocessor function.
34 Right-hand 'A' cylinder bank injectors and Looks for Injector dribble.
associated wiring.
36 Right-hand 'B' cylinder bank injectors and Looks for Injector dribble.
associated wiring.
44 Right-hand 'A' cylinder bank lambda sensor and Looks for feedback out of control rick or weak.
associated wiring.
45 Right-hand 'B' cylinder bank lambda sensor and Looks for feedback out of control rick or weak.
associated wiring.
49 Ballast resistor. Checks to ensure the minimum voltage of the ballast
resistor is achieved.
Old Apr 18, 2020 | 10:29 AM
Paul Mazel's Avatar
Default And mine is? FF 48!
and engine running.
associated wiring.
associated wiring.
associated wiring.
associated wiring.
48
JaguarLover101
48
Jun 12, 2023 10:28 AM
Msteiner
May 16, 2016 12:19 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
dmatthewman
Sep 30, 2015 10:10 AM
