Fitting tips for upper injector ring?
Old Oct 22, 2014 | 02:33 PM
Daim's Avatar
Default Fitting tips for upper injector ring?
hi there,
I'm redoing all rubbers in and around my engine and need to fit some new upper rubber mounting rings found on all 12 injectors.
Is there a 'trick' to fit them? Mine don't budge any further than the center dent/rut in the injector itself... Too low to fit properly...
Any tips or tricks?
Cheers!
Btw. clean intakes fitted to a clean engine look great!
Old Oct 22, 2014 | 03:51 PM
Brake buster's Avatar
push a bit harder to make em fit in the right place
thats what i did with mine
BB
Old Oct 23, 2014 | 05:29 AM
Daim's Avatar
I tried exactly that but no success... It gets caught on the upper injector edge...
Old Oct 23, 2014 | 05:34 AM
I use copious amounts of silicone spray.
Very sore fingers when the 12 are done no matter what.
Old Nov 1, 2014 | 04:05 AM
Daim's Avatar
Done all twelve... Was easier if you have the right stuff...
1. some insulating tape
2. some liquid soap
3. some rubber gloves
Wrap the insulating tape around the upper section of the injector.
Smudge some soap around the inner surface of the rubber ring.
Push metal ring on and then carefully wedge the rubber ring up.
Done.
Not much force needed. And when dry, it won't come loose
Took 10 minutes last night
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Jefro
Sep 15, 2015 01:44 PM
Bcrary3
Sep 11, 2015 10:36 AM
