Front Lower Wishbone Clunk
Old Apr 24, 2019 | 07:26 AM
orangeblossom's Avatar
Hi Someday
Those little rubber Shock Absorber Bushes have a really dramatic effect on Body Roll, so worth experimenting until you get the handling you like
My MOT Tester who missed these because they had rotted away, actually did me a favour because as I wanted to use the Car and got fed up with the banging sound that seemed to be coming from underneath the floor, I decided to make my own
So I Cut some out of a piece of Scrap Rubber (of the right thickness) and I couldn't believe the difference that they made
But the ideal combination for me, is rubber ones under the Wing/Fender and the Top ones cut from a Nylon Chopping Board
The difference was incredible and now She Corners as flat as a Pancake!
Old Apr 24, 2019 | 08:24 AM
Some Day, Some Day's Avatar
Nylon chopping board? You mean the standard sort of plasticky sort of chopping board? Or is this a special sort that I'm not familiar with? Because my plastic chopping board (no idea if it's nylon) is pretty hard, and I would imagine most chopping boards are.
Old Apr 24, 2019 | 12:10 PM
Hi Someday
Just a Bog Standard Nylon Chopping Board and not one that shatters when you hit it with a FBH but under the Wing/Fender I used rubber ones to help absorb the impact of the bounce
Old Apr 24, 2019 | 06:23 PM
Huh.
Okay, I would love to know the thought processes behind you deciding to use a chopping board to absorb shocks. Because they're good at absorbing blows from knives? Did you experiment with a range of weird and wonderful materials?
"Hmm. Dry toast doesn't work very well, even with grilled cheese. How about used chewing gum?"
Lawrence
Oct 4, 2014 02:21 PM
Billsblue73
Mar 18, 2014 08:06 AM
nurquhar
Nov 1, 2012 04:38 AM
shl1980
Aug 14, 2012 06:04 AM
dpm
Feb 9, 2012 08:57 AM
