Front wheels won't come off without a sledge hammer! XJS V12
Old Apr 26, 2014 | 04:32 AM
orangeblossom's Avatar
Default Front wheels won't come off without a sledge hammer! XJS V12
My Front Wheels have dust protectors which is good!
The only problem being that I cannot get the wheels off without using a sledge hammer (on the Tires)
Which could be a disaster, if you want to change a wheel by the side of the road and haven't got a sledge hammer in your Toolbox!
Any ideas what to do?
Should I put grease or something on the outside faces of the dust protectors?
I'm a bit wary of doing this as I don't want any grease spinning off with Centrifugal force and getting on to the brakes.
I did consider sprinkling some of the Girlfriends Talcum power on the dust protector covers instead of using grease (it might even work) but I am still undecided as to whether to use Lavender or Lilly of The Valley?
Old Apr 26, 2014 | 05:04 AM
ptjs1's Avatar
OB,
I don't know how your dust protectors are fitted, but the late XJS wheels are a bit prone to sticking on the hub face. I would make sure that you have a good smear of copperease on the hub face between the wheel bolts and also on the face of the wheel where it mates to the hub.
Paul
Old Apr 26, 2014 | 05:09 AM
Yep, ya get that on those "hub centric" systems.
I always put a smear of Copper Coat, or Anti sieze (Nickel), on the small snout of the hubs whenever they are off. It is a habit that goes waaaaay back.
Stuck wheels are a pain in any situation, and addressing this now is obviously better than on the side of the road, dressed to the Nines.
I had limited success with a Non Jag, by removing the wheel niuts and spraying copiuos amounts of WD40 thru the stud gap, using the small tube attachment, and then WAIT. Once off, some Brake Clean solvent to delube the brakes was all that was needed.
Old Apr 26, 2014 | 05:16 AM
Originally Posted by ptjs1
OB,
Paul
Hi Paul
Thanks, A small amount of Copper grease sounds about right, I will give that a try.
Old Apr 26, 2014 | 05:20 AM
Hi Grant
You are right, you certainly don't want that happening, by the side of the road!
Even a Club Hammer wasn't enough to dislodge them, I had to get the big guns out to do it.
Good job I found that out sooner rather than later!
I will try some Copper Grease!
Old Apr 28, 2014 | 07:45 AM
sidescrollin's Avatar
Try scrubbing the surface off with a wire brush first. If it hasn't had anti-seize on it all this time then it is probably a little rusty. Get it smooth and apply some grease. This is something recommended by many manufacturers. theres a TSB on my land rover for it
Old Apr 28, 2014 | 08:36 AM
Steve M's Avatar
And don't forget to put the new tyres on the fronts whilst they are off!
Ha, ha.
Old Apr 28, 2014 | 09:33 AM
There was no sign of rust whatsoever, which makes a change!
So I gave them a Coating of Copper Grease and put the sledge hammer away.
Old Apr 28, 2014 | 09:34 AM
Ha, ha.
That is exactly what I am going to do!
Old Apr 28, 2014 | 10:48 AM
Doug's Avatar
Just jumping in because you mentioned 'grease'....
For the purpose of preventing the wheels from getting stuck onto the hubs, ordinary 'high temp wheel bearing grease' will do the job perfectly well. There's no particular need to use a (surely more expensive) anti-seize product. Unless, of course, it makes you feel good...a perfectly understandable notion
Also, if your arm gets weak from sledge-hammering.......
Loosen the lugnuts one or two turns and then drive the car....slowly....like walking-pace...thru a couple figure-8 patterns. This will break the wheels away from the hubs.
Old Apr 28, 2014 | 12:32 PM
Steve M's Avatar
How is that going to be helpful?
Attached Thumbnails Front wheels won't come off without a sledge hammer! XJS V12-wheel.jpg
Old Apr 28, 2014 | 01:33 PM
Gunner01's Avatar
LOL, no one even commented on this ( but I am still undecided as to whether to use Lavender or Lilly of The Valley?
I guess all the guys are doing it ;0
Old Apr 28, 2014 | 01:42 PM
Doug's Avatar
heh heh
I said 'break away' not 'fall off'....although it's a subtle distinction for some
Old Apr 28, 2014 | 04:54 PM
Hi Doug
'Grease may be the word!' But instead I am using 'Yardley's Sandalwood' Talcum Powder as worn by my GF.
The Wheels don't stick and they smell gorgeous, which will hopefully help Her pass the MOT! (That's the Car not the girlfriend!)
But you have to give her a good rub down, before you sprinkle it on.
(That's the girlfriend, not the Car!)
Love the idea of driving around in a figure 8 with the wheelnuts undone!
I wonder what the boys in blue are going to think about that!
Old Apr 28, 2014 | 04:57 PM
Love it! LMAO!
Old Apr 28, 2014 | 05:00 PM
Mikey's Avatar
That trick has always worked for me.
Old Apr 28, 2014 | 05:03 PM
We decided to go for 'Yardley's Sandalwood' It make those wheels smell Gorgeous! (grease seems to cause a suction)
Old Apr 28, 2014 | 05:06 PM
You haven't seen the width of our roads! lol
Old Apr 28, 2014 | 05:27 PM
Steve M's Avatar
I suppose that nice smelling wheels would be advantageous to any pedestrians that you run over, sort of a nicely scented apology.
Passed my MOT today (that's me not the car), fit for work for another 2 years.
Old Apr 28, 2014 | 05:34 PM
After all the hard work that I've put in, that's the last thing that I need!
