front wishbones
Old Jan 13, 2018 | 06:02 PM
catterwaller's Avatar
Default front wishbones
I have the front suspension disassembled for rebuilding. I sent the lower wishbones out for powder coating along with some other parts. I have them back and started looking at reassembly. off hand I don't know which side is which. Can someone tell me which way the ball joint mount is located? Does it bend forward or back? There are part numbers cast in them but none of my catalogs show a part number for a lower wishbone. There might be an arrow cast in them also but the powder coat thickness obscures it.
Old Jan 13, 2018 | 09:52 PM
baxtor's Avatar
The wishbones angle back and balljoint mounting point needs to point forward for an end result of balljoint mounting points more or less pointing straight out to the side. Hope that makes sense?
Old Jan 14, 2018 | 08:12 AM
Thanks. I think I get it. Once I get out and fit one up Ill know better.
Old Jan 15, 2018 | 05:37 PM
Here it is then.
Right side is C41314.
Left side is C41315.
Trilapis
Apr 9, 2016 09:33 PM
aode06
Oct 23, 2013 09:27 AM
luv2fly
Sep 11, 2012 06:29 PM
brayshaw36
Aug 30, 2012 03:24 AM
