fuel filter replacment
Old Dec 21, 2014 | 11:29 AM
bobnuttall1's Avatar
Default fuel filter replacment
where doI find the fuel filter on a '95 XJS 6cylinder?
Old Dec 21, 2014 | 12:29 PM
Vee's Avatar
Vee
Drivers side fromt wheel well. It's on the rear inside corner of the well. You'll have to remove the plastic wheel well cover.
Old Dec 21, 2014 | 12:56 PM
ptjs1's Avatar
bobnuttall1,
Just a suggestion: Leave the mounting bracket done up and slacken both top and bottom nuts of the filter a 1/4 turn before removing either one of them. Otherwise, if one is seized and you remove the other end, or remove the bracket nuts, it can be a complete pain to undo the seized filter end. I know this!!
Whilst it's apart, it's a good opportunity to paint the mount bracket and clean any corrosion of the pipes where they turn at the bottom.
Remember that when you change the filter, you should remove the fuel pump relay in the right front side of the boot, then turn the starter for a few seconds to release fuel pressure, then remove the filter.
Good luck
Paul
Attached Thumbnails fuel filter replacment-_scf1158.jpg   fuel filter replacment-_scf1163.jpg   fuel filter replacment-_scf1165.jpg
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
