fuel gauge wiring
Old Feb 27, 2011 | 05:20 PM
sidescrollin's Avatar
Default fuel gauge wiring
anyone know the order of the 3 wires on the sending unit? My gas just reads empty and I think its wired wrong.
thanks!
Old Feb 27, 2011 | 07:33 PM
EcbJag's Avatar
hope this helps..
Old Feb 28, 2011 | 03:10 AM
Talking
thanks man this is exactly what i needed
Old Feb 28, 2011 | 02:50 PM
EcbJag's Avatar
No problem! Was it wired wrong?
Old Aug 14, 2013 | 05:37 PM
Jaguar2986's Avatar
Does anyone have a photo of the other end of the wires? My fuel sender is wired, but two of the four wires at the other end are not connected to anything. Does one plug directly into the + cable? I have a spot there that is missing a wire.
Thanks!
Old Aug 15, 2013 | 01:12 AM
Greg in France's Avatar
Thanks!
Could you explain what you mean by the 'other end', and the 'four wires' or post a photo? The gauge wires go into the instrument pack via two large black oblong plugs with copper connectors, and thence to the instruments.
Greg
Old Aug 15, 2013 | 08:45 AM
Doug's Avatar
I don't understand either. The sender should have 3 wires: one to ground, one to the low fuel warning light, and one to the fuel gauge itself. That wiring (except the ground wire) runs forward to a connector in the console and from there to the connector at the instrument cluster
ccfulton
Sep 20, 2015 05:15 PM
adamn
Sep 10, 2015 09:23 AM
1964Daimler
Sep 9, 2015 11:28 AM
Bones
Sep 8, 2015 08:34 PM
AL NZ
Sep 4, 2015 08:39 PM
