Gearbox confusion-'93 4.0
Old Aug 2, 2018 | 01:21 PM
Rick25's Avatar
Default Gearbox confusion-'93 4.0
Hi folks,
I have a question about the gearbox related to my '93 xjs 4.0 conv, built in September of 1992. I ordered a new gearbox filter and gasket from Rockauto. When it arrived I discovered that both the filter and the gasket were quite a bit larger than my gearbox could possibly handle. Rockauto wouldn't accept the return so I'm sitting here looking at these two and hating to throw out a new filter and gasket because it's the wrong one. The one they sent says it's for an L6? How can I describe these so I can pass them on to someone who can actually use them? Thanks for your help.
Old Aug 2, 2018 | 01:44 PM
Jagboi64's Avatar
I had a quick look at the Rockauto listings. They are mixing the V12 and 6 cylinder applications under the 6 cylinder listing. If it says the trans type for the brand you bought then you can figure it out. The V12 used the GM 4L80E transmission the 6 cylinder used the ZF 4HP22 transmission.
If the pan gasket is basically rectangular, it's the GM application. If it's a trapezoidal shape, it's ZF. Instead of the XJS, look at the XJ6 listings,the transmission is the same on both 4.0 cars (XJS and XJ6).
Old Aug 3, 2018 | 09:32 AM
Rick25's Avatar
Thanks Jagboi64........looks like they sent me the filter/gasket for the GM 4L80E. I'm glad you spotted their application confusion. They were trying to tell me it was my fault.
Thanks again.
Khb1
Mar 6, 2018 03:05 AM
srjag
Detailing / Car care
Jan 17, 2010 07:11 PM
srjag
Nov 25, 2009 09:59 PM
oldmots
Sep 1, 2008 08:23 AM
Tomcat
May 14, 2008 08:09 PM
