Glove box flooding in June
Old Jun 6, 2011 | 11:59 AM
EcbJag's Avatar
Question Glove box flooding in June
Well alas Jaguars are not the only things in the world with unpredictable spells. So here I am in June with pouring rain and 4 friends stuck outside after diner. (And me in my xjs with a backseat that might as well be non existent. So five soaking wet people in an xjs with towels thrown over all the seats and me fearing for my cars near perfect condition. You should try it sometime. NOT! (long story I'll cut to the chase). After the festivities were over, the next morning I commenced a damage report. Surprisingly the car cane out unscathed with no damage to the seats, or carpets. But the car smelled slightly musty. That day wasn't much better as far as weather so I just rolled down the windows in the garage. Later that day I checked on the progress and I had to get something out of my glovebox. what do ya know! There is like an inch of sitting water in there! Now I thought the glove box was sealed all the way around? I pulled the bottoms of the dash out (under scuttles?) an they were bone dry. My window seal has a small leak above my head but how could a leak account for the glow box flooding and the rest being dry? It was raining really hard but I'm stumped.
Old Jun 6, 2011 | 01:41 PM
Doug's Avatar
Water leaks are funny. The water meanders around and takes strange paths, finally dripping some distance away from the actual source of the leak.
I can almost promise the the windshield leak is the root casue
Old Jun 10, 2011 | 02:19 PM
clarku's Avatar
Default how about...
Could clogged drains from the wiper vent that exit to the wheel wells be the culprit? I noticed some debris in mine (by giving them a little squeeze I could hear leaves crunching inside them)...it's on my to do list.
Old Jun 10, 2011 | 03:22 PM
i_like_ike's Avatar
My drains were plugged and were contributing to my water problem. Mine would leak behind the dash and come out the floor vents. However, my windshield was also leaking around the corners. I'd flush out those drains, and then check to see if the water continues coming in. If the windshield gasket looks cracked or dried out just replace it cause it will probably start leaking in the near future anyway.
Old Apr 17, 2012 | 04:55 PM
HeyCharger's Avatar
Originally Posted by EcbJag
....Later that day I checked on the progress and I had to get something out of my glovebox. what do ya know! There is like an inch of sitting water in there! Now I thought the glove box was sealed all the way around?.....
Anyone found a (dry) solution? Mine (Cabriolet) is the same. Any rain and it pools in the glovebox. Lots of it.
Old Apr 17, 2012 | 07:53 PM
Greg Edge's Avatar
Water can do some crazy things. You can set up a garden hose with a watering hose end that they sell in Home Depot or the like. It sprays similar to a shower head. Then either rig it to spray the car where you want or have a helper hold it. Then grab a flashlight and climb in the car and watch the water. Disassemble as needed to find the source.
My money is on a combination of clogged drains and a windscreen seal.
Old Apr 18, 2012 | 09:30 AM
MustangSix's Avatar
+2 on the plugged drains. Remove them, clean them out, and you should be good to go.
Poet
Feb 7, 2025 02:18 PM
Johncy2000
Oct 2, 2015 01:05 AM
o1xjr
Oct 1, 2015 09:46 AM
BSM
Sep 25, 2015 05:00 PM
