Halo quad headlamp conversion
Old Nov 25, 2012 | 07:22 AM
philhef's Avatar
Default Halo quad headlamp conversion
I recently purchased the four replacement headlamps that converts the existing sealed beam to the LED halo stlyle with replacable H4 bulbs.
I was wondering if anyone has swapped these out yet. My car is dismantled right now being painted so I know there is no major modifications necessary to fit deeper bulb, only a small notch to allow wires for LED halo to fit properly. I'm going to wire them to stay on as DRL with a switch under the dash. I may also loose the factory driving lights for a sleeker LED style.
I tried out the LED protion and it looks really amazing.
Old Nov 26, 2012 | 06:13 AM
kennith13's Avatar
Where are you in NC, and what year is it?
Old Nov 26, 2012 | 12:26 PM
JagZilla's Avatar
What brand are the lights,and which vendor did you use?
Old Nov 26, 2012 | 05:41 PM
Greg Edge's Avatar
Hopefully they are bright. All I can think of is LED flashlights which almost everyone I have tried is not nearly as bright as a normal flashlight. I did see one that was very bright but the guy who owned said it cost nearly $350.
Although with all the voltage drop in the lighting circuit on the XJS it would be hard to be dimmer than stock headlamps. The LEDs should have less voltage drop which will help be brighter too.
Old Nov 27, 2012 | 05:43 AM
philhef's Avatar
Hickory NC, and a 1988 coupe.
Old Nov 27, 2012 | 05:51 AM
philhef's Avatar
Bought from chevyracer on eBay. They use a standard H4 plugi-n hallogen bulb for the actual functioning headlamps. The LED is only the outer halo ring, similar to a newer BMW. I do have to cut a small notch to allow the LED wiring to clear the retaining ring but I plan to add a switch to turn them off if I don't want them on.
Basically, unless the LED rings are on, they will look like "regular" bulbs, just a little newer.
jagtoes
Apr 22, 2016 07:37 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Samheath100
Sep 17, 2015 10:03 AM
Nasayr
Sep 9, 2015 06:20 AM
