Hard Shifting - Transmission Light
Old Apr 4, 2016 | 12:55 AM
hoodun's Avatar
Default Hard Shifting - Transmission Light
1994 L6 XJS 130k - daily driver for 5 years
I am getting hard shifting at times. Its usually when I just start the car. It will lunge into gear and the trans light will come on. I restart the car and the problem is fixed. Drained transmission fluid about 18 months ago and replaced filter. There have been no issues, until now. The fluid level is ok.
This has been happening about once a month for three months now. Any ideas? Solenoid? Torque converter? I also sometimes get hesitation when going up hills.
Old Apr 4, 2016 | 03:29 AM
Steve M's Avatar
Are you sure that you are checking the fluid level properly?
It must be up to temperature and you must run through all of the gears (including reverse) before you check it.
Do a minimum of 3 level checks and average them out.
Old Jun 6, 2017 | 06:38 PM
dtony's Avatar
Did you resolve your Trans light issue???
Tony
pricebill
Mar 22, 2016 06:38 PM
sssbl17
Sep 18, 2014 12:01 PM
xclusive_s
Aug 11, 2014 12:24 PM
XJS720
Aug 27, 2013 03:43 PM
Helpingdad
Mar 24, 2013 09:22 PM
