Help please with Teves III connector(s) info
Old Jun 5, 2015 | 11:27 PM
Greg's Avatar
Default Help please with Teves III connector(s) info
I have read through the dozens of posts and pages of archives, and I still need some.
I need to know exactly how to test the '90 XJ-S ABS valve block
solenoids. I know to apply 12VDC to each of the solenoid
contacts in the valve block connector, but I do not know
which way the connector tabs are numbered (and I am not going
to make any assumptions, after all, it is a Jaguar).
So, is PIN 1 on the left or the right when looking at the
connector? I also need the same information for the ABS ECU
connector and any tips that may be applicable. All replies
greatly appreciated.
Thanks in advance, and yes I am a newbie.
Old Jun 6, 2015 | 04:50 PM
orangeblossom's Avatar
Hi Greg
This should solve your problem:
RennsportKC ? Jaguar XJS ATE ABS repair?
https://www.jaguarforums.com/forum/x...photos-140828/
Old Jun 6, 2015 | 11:27 PM
Greg's Avatar
Hello OB. Thanks, I appreciate your. Actually, I had found and copied ALL of your thread about repairing the actuator/master a week ago (it is 45 pages in a MS Word document) and found it MOST helpful. i think my problem is that i have done so much research that i have confused myself.
Your other link, to the RennsportKC blog, was also very helpful as it showed me which terminal to connect my VOM negative to. Thanks. i will let you know what I find out.
Old Jun 6, 2015 | 11:42 PM
Hi Greg
I am going to add that RennsportKC blog to my own Post, so that its altogether, in case anyone else gets a problem.
Poet
Feb 7, 2025 02:18 PM
Rocky15
Sep 28, 2015 04:59 PM
dieseldoc
Sep 28, 2015 01:17 PM
Martin111
Sep 25, 2015 08:41 AM
Lannyl81
Sep 19, 2015 08:07 PM
