Hesitation when taking off.
Old Dec 14, 2012 | 10:27 PM
macdoesit's Avatar
Banned
Default Hesitation when taking off.
Motor has slight hesitation when taking off from stop do I need injector cleaner ?
Old Dec 14, 2012 | 11:01 PM
JTsmks's Avatar
I'd make sure the throttle butterfly's are set properly then make sure the mechanical advance is working properly as well as the vacuum advance and that the engine is firing on all 12 cyl's and all 12 injectors are "clicking" also check all vacuum connections as well as the x-over pipe. Believe me you'd be surprised how hard it is to tell it's not running on all cyl's. I'd also download Kirby Palms book and browse through it just to get some general insight on things and common faults with these cars. Hope that helps, I'm sure others will chime in.
Old Dec 15, 2012 | 01:21 AM
warrjon's Avatar
My first guess would be the throttle linkage bushes are either toast or missing. These are located on the opposite end of the shaft from the throttle body, this shaft goes into a bracket mounted on the plenum this bracket should have bushes in it that hold the end of the shaft.
I had this same problem my bushes were missing. This allows the TB butterfly to close slightly as you touch the throttle
Old Dec 15, 2012 | 09:43 AM
Greg Edge's Avatar
The last thing you need is injector cleaner. The first thing is to clean and set your throttles, make sure the throttle linkage is adjusted properly and the bushings are intact. Also check TPS operation and adjustment.
Old Dec 15, 2012 | 11:00 AM
ATL Dave's Avatar
What they said: But your TPS (throttle position sensor) may have a bad spot in it too...
Dave
Old Dec 15, 2012 | 02:22 PM
JTsmks's Avatar
Throttle Position Sensor Testing
Old Dec 15, 2012 | 04:26 PM
macdoesit's Avatar
Banned
Drove the car little over 100 miles today runs fine the first thirty minutes of stop and go when I got off the highway and stop and go again then the hesitation started.. Thank you for all the replies, will check what everyone said.
CRC@Jaguar
Sep 15, 2015 03:23 AM
Bones
Sep 8, 2015 08:34 PM
Dymaxxion
Sep 4, 2015 02:40 PM
carpartsdiscount.com
Sep 4, 2015 02:29 PM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
