High Idle
Old Jun 1, 2009 | 12:04 AM
ekw540's Avatar
Default High Idle
Hope someone can help me with this issue.
1995 XJS 4.0
The car has high rev upon startup (1500+ RPM) and stay there. I have waited up to 15 minutes and it doesnt drop. I had to manually close the butterfly and it settles to 700. I get in the car give it a little gas and it goes up again (say 1200); give it a little more gas and up again to 1800; it always going up but not coming back down. I then force to close the butterfly (on top of TB) and it settle down.
I had cleaned the TB already. Could it be the Idle Control Valve (Stepper motor) is bad?
As I was taking out the ICV, I snap off both of the bolts
A machine shop closeby luckily was able to help drill it out after me spending 2 hours unsuccessfully.
Old Jun 1, 2009 | 12:20 AM
ekw540's Avatar
Default High Rev II
There is also a sensor on the bottom of the TB, which I assume is the throttle position sensor (TPS)? Can that be bad? That part has a Ford logo on it .
hoodun
Nov 20, 2022 02:35 PM
bdboyle
Sep 16, 2019 05:58 PM
GGabriel
Nov 22, 2018 03:53 AM
JCam
Oct 23, 2016 08:27 PM
driver safz
Sep 26, 2015 06:01 AM
