How tight?
Old Apr 16, 2013 | 10:23 PM
macdoesit's Avatar
Banned
Default How tight?
How tight do you get the front shock bushings and how do you keep the shock shaft from turning with the nut ?
Thank you.
Old Apr 16, 2013 | 10:50 PM
Doug's Avatar
Rule of thumb is tighten until the bushing is squished to the same diameter of the washer. This might be too much for the original foam-type bushings Jaguar used....or if an extra thick rubber bushing is used. At minimum make sure the bushing is squished to some degree....but you don't want to crush it to death!
The end of shock shaft should have two flats. You can use a small wrench or vice grips on the flats while you undo the nut.
Or.....
Go to Sears or a good tool supplier and you can get a socket that fits the end of the shock absorber shaft perfectly
Looks like this
http://images.monstermarketplace.com...91-250x190.jpg
Some call these a "Double D" socket but if you Google "Shock Absorber Socket" you see many listed.
Old Apr 16, 2013 | 11:02 PM
macdoesit's Avatar
Banned
Or.....
Looks like this
Doug, Thank you again.
ericjansen
Dec 19, 2021 12:20 AM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
indi4ever
Oct 8, 2015 10:23 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
JagLove86
Sep 22, 2015 06:27 PM
