Identifications please
Old Mar 26, 2012 | 05:02 PM
markman's Avatar
Default Identifications please
Hello,
What is this being used for? There are two of those straps in the back.
This hose exits in the rear right trunk side
and just dangles around. What should it be connected to?
Thanks, Mark
Old Mar 26, 2012 | 05:18 PM
warrjon's Avatar
Don't know what the strap is for but the hose is a drain for the boot lip, There is a drain above the fuel tank just to the right of the boot hinge.
There is a drain on the other side as well that drains the fuel filler nook and the boot make sure these are connected and clean, this is one major cause of rust in the lower sills.
Old Mar 27, 2012 | 01:59 PM
Sarc's Avatar
The strap in pic 1 is used to keep the top boot cover in place. the top boot cover has 2 metal hoops that you put underneath this strip, one per side, then clip the straps in place on each side.
This prevents air getting underneath the top boot cover and wafting about at speed
General Tech Help
37
Dec 1, 2025 12:43 PM
Translator
General Tech Help
37
Sep 27, 2016 11:53 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
richzak
Aug 23, 2014 02:43 PM
