Jaguar xjs engine shake at idle
Old Aug 4, 2021 | 05:41 PM
jagowner659's Avatar
Default Jaguar xjs engine shake at idle
Hey all my 1994 Jaguar xjs 4.0 has developed a nasty shake at rpms below 1500 and I’d like to have some idea of what’s wrong before I take it in any advice would be much appreciated
File Type: mov
Old Aug 5, 2021 | 05:15 AM
ptjs1's Avatar
Perhaps start by checking the integrity of the connections on each spark plug lead. Also check that the spark plug recesses have not got puddles of oil at the bottom which causes the spark to break down and will be more noticeable at idle.
Good luck
Paul
Old Aug 5, 2021 | 09:46 AM
Xjeffs's Avatar
Good luck
Paul
This becomes very obvious in the dark too. You can see the spark jumping to the engine block.
Old Aug 6, 2021 | 10:33 AM
92/93 XJS's Avatar
I just solved a "shake, bad idle" issue on my 93. Turned out to be a bad idle speed motor combined with hard to find air leaks.
Good luck!
Dave in AZ
Andreas Schmieg
US Midwest
Jan 5, 2024 01:39 AM
orangeblossom
Feb 28, 2016 11:13 AM
88-xjsv12
May 3, 2014 12:20 AM
jetlag700
Oct 16, 2010 06:27 AM
drat9000
Apr 28, 2010 01:51 PM
