jaguar xjs - horn works sometimes
Old Jul 18, 2013 | 10:50 AM
jameslast's Avatar
Default jaguar xjs - horn works sometimes
I have a Jaguar xjs 1995
The horn works sometimes....I hear that they sometimes suffer from a break in the wiring within the steering column. Is this true and if yes, how can it be tested please?
Thanks very much
JL
Last edited by GGG; Jul 18, 2013 at 12:33 PM. Reason: edit thread title to add detail
Old Jul 18, 2013 | 12:31 PM
Welcome to the forum JL,
I've moved your question from General Tech Help section to XJS section. You need advice from members with the same model on this issue.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Jul 24, 2013 | 01:05 AM
mirisisa's Avatar
First thing I would do is to check the horn relay. It always seems to come down to the darn relays...
The horn relay is the middle blue Hella relay in the right front component panel under the hood. This panel is covered with a piece of plastic held on by a couple of plastic blots. Swap the relay with one you know works (ie A/C Clutch Relay, which is the next door neighbor of the horn relay, closer to the front of the car) and see if your problem is fixed. If so, replace the relay and you're good as new.
Best,
Old Jul 24, 2013 | 05:03 AM
jameslast's Avatar
Best,
Thank you very much indeed for your, could be simple, suggestion. I will give it a try. Very many thanks.
James
1100me
Aug 27, 2020 11:37 PM
chipnping
Mar 8, 2016 10:33 PM
DrScientist
Dec 9, 2015 07:36 PM
johnnie ryall
Oct 19, 2015 09:44 PM
