keyway
Old May 9, 2014 | 03:22 AM
rgp's Avatar
rgp
Default keyway
just fitting a serpentine type engine damper and found a baggy crank keyway slot, bit of araldite is could for or any other suggestions please
Old May 9, 2014 | 04:07 AM
baxtor's Avatar
Yours will use the cone arrangement which will hold damper solid so long as the crank bolt is properly torqued. The key does very little apart from location if the bolt and cone are locked up correctly.
The fact the keyway is flogged out a little might indicate the bolt was not as tight as it should be.
Old May 9, 2014 | 04:32 AM
rgp's Avatar
rgp
your right, the weight of the breaker alone nearly undid the bolt and the pulley, cone and all just pulled off, so providing the correct torque is used on refitting. do you think I can get away with it I have new woodruffs coming tomorrow,
Old May 9, 2014 | 06:10 AM
Agreed.
The keys do get a little "hammering" with the "on/off" of the A/C compressor. Properly torqued and that "hammering" is extremely slight.
However, that small amount of wear will have the key to cone relationship not perfect.
I would get some JB Weld, Devcon, or similar stuff in your market, to try and redress that groove somewhat. Araldite would be too weak/soft in my opinion.
The NEW keys will make a HUGE difference, and may well be sufficient.
Old May 9, 2014 | 06:13 AM
rgp's Avatar
rgp
thanks grant
Old May 9, 2014 | 02:02 PM
rgp's Avatar
rgp
got the j b weld from amazon and 10 keys (min buy) from jaguar today
so if any one wants a couple of woodruff keys for cost give me a shout
billbjork
Oct 30, 2021 09:18 PM
ls99
Aug 29, 2014 07:49 PM
aholbro1
Sep 1, 2013 12:31 AM
markystype
Jul 23, 2009 02:21 PM
