Knee bolster repair clip
Old Oct 13, 2025 | 08:27 AM
monkfe's Avatar
Default Knee bolster repair clip
Here are some pics of a repair clip I made for the knee bolster. It requires you drill (and debur) a 3mm hole once positioned. It uses 3mm nut and a 3x6mm machine screw to hole it in place. I used a countersunk screw, but It needed to be around 7mm long(which required some grinding), so I changed the final design and went with a 6mm pan head screw. Before placing it in place I recommend you get upside down and observe how it going into place. I had to rebend one of my brackets( the vehicle mounted bracket) as it had bent slightly upward after being abused over the years. I haven't put too much time on it yet, but it seems to be holding nicely. Here is a link to the 3d file https://www.thingiverse.com/thing:7170014
Old Oct 13, 2025 | 12:39 PM
rgp's Avatar
rgp
Are these a facelift parts because I can't see anywhere they would clip on to on my pre-face lift car
Old Oct 13, 2025 | 02:22 PM
monkfe's Avatar
Mine vehicle is a 94 XJS so If you don't have them, that would be a yes.
Old Oct 22, 2025 | 03:47 PM
Scottsxjs95's Avatar
Those are nice , now you should make a latch or release, to open for a small glove box or phone storage, or a place to keep paperwork. There is some space behind the bolster.
Old Oct 23, 2025 | 06:57 AM
monkfe's Avatar
Yeah I don't think the juice would be worth the squeeze...there is really very little room there....and its a little precarious to install these as it is now, but I guess it could be done- but too many other projects to deal with right now.
Old Oct 23, 2025 | 10:03 AM
Vee's Avatar
Vee
I keep my Class D amplifier in there. The AC system has to be kept on manual since the heat from that amp changes what the system believes is the ambient air temperature.
Old Oct 23, 2025 | 01:47 PM
equiprx's Avatar
That repair is very close to how I made mine.
Except I pop-riveted the original metal clip.
Jaguar owners are master mechanics.
benji808
Jun 1, 2025 09:31 AM
Czechbikr
Sep 23, 2024 10:21 AM
scottatl
Jun 19, 2024 05:20 PM
ozguy
Sep 18, 2022 11:02 PM
JaguarXKR
Oct 28, 2018 07:07 PM
