Lambda O2 Sensors
Old Jun 25, 2023 | 05:49 AM
Robbo D's Avatar
Default Lambda O2 Sensors
Hello all.
The post on O2 sensors has got me thinking. Mine are probably the original from when the car was made so my question is would it be wise to change them. I’m not sure what sort of signs a failing sensor would produce. You thoughts as always much appreciated.
Rob.
Old Jun 25, 2023 | 07:50 AM
Vee's Avatar
Vee
Failing oxygen sensors will usually show up in higher emissions and lower fuel economy.
If they are original, I would make plans on changing them. They aren't made to last forever. Without knowing the miles on your car, I can't tell if you're due, but I would at the very least acquire a set and have them ready.
Old Jun 25, 2023 | 07:58 AM
Robbo D's Avatar
Hi Vee. My car has around 60k on the clock. No problems with the emissions when it was motd in April. Tested with very low emissions.
Rob.
Old Jun 25, 2023 | 08:28 AM
Greg in France's Avatar
Rob.
Leave well alone, Rob. But get a couple in the Christmas stocking so you are ready when they do fail!
Old Jun 25, 2023 | 11:33 AM
Robbo D's Avatar
Hi Greg. Thanks for the advise which is heeded. What would be the signs of a failure to look out for.
Rob.
Old Jun 25, 2023 | 11:39 AM
Robbo
I think poor fuel consumption, ie overfuelling, plus MOT failure on emissions! But I know nothing about these things in a XJS. I think that, in some non-Jaguar applications at least, if they fail the ECU thinks the engine is cold and shoves in fuel as a consequence.
JacksonvilleJag
F-Pace (X761) / C-X17
Mar 7, 2022 12:37 PM
JaguarJackson
Jun 7, 2021 08:30 AM
justcruzin47
May 15, 2021 01:39 PM
RonnieJoe
Jun 13, 2015 06:48 PM
gbdiver
Jun 18, 2009 12:55 PM
