Leaky drivers side window
Old May 2, 2022 | 12:27 PM
Fergie's Avatar
Exclamation Leaky drivers side window
How do I fix this, new seals.?
Old May 2, 2022 | 01:57 PM
WayneC's Avatar
Where is the leak on the window?
Old May 2, 2022 | 02:42 PM
Fergie's Avatar
Water comes in at the top right side of driver’s window.
Old May 2, 2022 | 03:34 PM
WayneC's Avatar
Did you mean the top front corner? Sounds like seals to me, can you see any issues with the seals? (eg, distorted, torn, etc). If the seals look fine, then maybe the window fit?
Is it leaking between the window glass and the door frame, or is it coming from above the door frame and flowing/dribbling down inside and then onto the window?...
Try using a hose (with water stream flowing at low pressure) or an empty squeeze bottle (soap detergent, etc) filled with water to direct water carefully at various places near that area (start low and work upward) to see where the water gains entrance.
Maybe just needs a bit of rubber sealant repair (something like JB Weld black silicone RTV), or a straightening of the seal and re-glue, or a slight adjustment of the window angle.
If it's a large leak, then you'd need to replace the seal(s).
Or, you might try stopping at a repair shop that specializes in replacing windshields & other glass, they likely have experience tracking down and sealing window leaks.
Old May 2, 2022 | 04:10 PM
ptjs1's Avatar
If its a late Convertible it's extremely likely to be the join between the 2 seals that are at the front edge of the hood (roof) seal channel that contacts to the top of the door glass
I dont think they have been available from Jaguar. Have a look at the alignment to the door glass. You can also use a silicon sealant to fill the gap between the longer seal and the short bit at the front edge of the hood(roof).
Good luck
Paul
Old May 2, 2022 | 04:20 PM
ptjs1's Avatar
Duplicate post. Apols
Old May 4, 2022 | 12:21 PM
WayneC's Avatar
Good point, ptjs1, I was assuming a coupe, but could well be a convertible.
jag7252
US Southwest
Mar 7, 2022 01:56 PM
Bigfella
May 3, 2015 09:39 AM
02silver_x-type
Dec 22, 2014 07:45 PM
thefixer
May 29, 2011 08:17 PM
JP10501
Dec 7, 2007 06:16 AM
