A little sneak preview of my transmission swap...
Old Nov 30, 2018 | 06:44 PM
JessN16's Avatar
Default A little sneak preview of my transmission swap...
This came today. This is just the shifter. I'll put a longer post up with the rest of the build outlined in it once it's done.
Jess
Old Dec 1, 2018 | 02:59 AM
brinny's Avatar
Jesus, never seen anything like that before
Old Dec 1, 2018 | 02:42 PM
warrjon's Avatar
Rachet shilfer for a 4L60/700R4. Used in drag racing often with a reverse shift pattern.
Old Dec 1, 2018 | 02:44 PM
VancouverXJ6's Avatar
Which one engages the afterburners
Old Dec 1, 2018 | 03:56 PM
JigJag's Avatar
**** warning, please!
Old Dec 1, 2018 | 05:14 PM
JessN16's Avatar
This one is called a Lightning Rod shifter from a company called Kilduff Machine. It's very similar to an option that used to be factory-orderable from Oldsmobile on, I believe, the 442.
Here's the shop's website: custom automatic ratchet shifters
They make several shifters (including the old-type single ratchet) but this one allows you to both upshift AND downshift, sequentially, without a clutch. Or you can just pull it into "D" and the car will run like it has a regular automatic transmission in it.
Here are a couple of videos about how they work. Modern Pontiac GTO:
Also a video from a '68 Camaro showing you how easy it is to upshift/downshift:
Jess
Old Dec 2, 2018 | 01:41 AM
Dukejag's Avatar
Looks like a 747 throttle control.... driving home from the pub could be an issue when they all look the same..!
Just push them all forward and pray!
GGabriel
XE ( X760 )
Apr 8, 2016 06:54 AM
Michael Star
Oct 3, 2015 01:31 PM
ufoz8mycow
May 29, 2013 02:18 AM
