LIVE Repair
Old Mar 31, 2015 | 04:21 AM
mrtalkradio's Avatar
Live Video resumes at 1pm ny time 3-31-15
Old Mar 31, 2015 | 10:12 AM
Flint Ironstag's Avatar
Damn, I missed this.
Old Mar 31, 2015 | 12:59 PM
On Live Now 2p NY Time Watch it here
Old Mar 31, 2015 | 05:47 PM
Thanks for watching, for those who did. Quite a frustrating day today, none the less, tomorrow I will put the cage back in.
Old Apr 1, 2015 | 01:19 PM
Continuation of the LIVE repair work is now 2:19p ny time watch it here hopefully not as much choice language today
Old Apr 1, 2015 | 04:59 PM
Hooking up brake lines, emergency cables and lifting rack cage back into place, homestretch here 6p 4-1-15 LIVE
Old Apr 3, 2015 | 10:22 AM
Hopefully, without anymore issues, the rear cage with new calipers, rotors and pads will be installed and bled. If you would like to watch you can do so here Warning No speakers on at your workplace.
Old Apr 3, 2015 | 01:12 PM
  #28
Rear cage reinstalled. Transmission Leak is next, stay tuned
Old Apr 5, 2015 | 05:27 AM
Removing Collision Bracket and Transmission pan. Replacing pan gasket, fluid and filter on a 1987 HE XJS Jag you can watch it live here starting at 6:45a ny time 4-5-2015
Old Apr 5, 2015 | 06:19 AM
  #30
If you need to remove the collision bracket as I am, use a jack to hold it up. It is under extreme pressure, if you were watching, it pinned my finger between the bracket and exhaust pipe, I had to use all the strength I had with my shoulder to relieve the tension to get my finger out. just a heads up
Old Apr 5, 2015 | 06:51 AM
  #31
Ok, if you go here you'll see tranny fluid at the junction from the transmission to the rear, would this be a rear seal leak? What is that called there?
1LowCat
Sep 14, 2015 07:51 PM
Shaggy9212
Sep 14, 2015 07:47 PM
Vector
US Lower Atlantic
Sep 13, 2015 03:01 PM
teacoff
Sep 10, 2015 08:25 AM
