LIVE Repair
I used one of these, but mine was from sears. Put the cam end into the hole and bash it sideways with a BFH.
thanks, only thing I'm missing is live interactive audio, its called a rear radius arm, it does come off from the wishbone, crazy nut though 19mm with a shaved end to make clearance for the shock mount, amazing
I thought you were talking about the trailing arm which controls forward and backward movement of the cage. You use the pry bar to get the forward end of the trailing arm off the body, after taking out the long fine thread bolt.
If you need some slack there's a nut and locking nut at the end of brake lever in a recess in floor in the car. Its used for getting the correct tension.
Great job! very impressive!
I drop them off the body, and deal with that nonsense on teh ground.
Now I have them on the ground inside an hour. The trailing arms to body are the time consumers sometimes. BFH, as in a Sledge hammer, does aid removal.
Would it be as good to undo the Trailing Arm at the other end?
Providing the rubber bushes look ok.
Of course, but at some stage ther gotta come off.
I have had a few where I sprayed "penetrating oil" thru the gap at the top of the large bush and the body, so that it runs into that tapered snout, for about 2 weeks before doing the job, and they simply pop off.
If that snout pulls out of the floor, and Pommy cars do have that issue thanks to salt rust, a body shop that is half decent can reweld a snout fairly simply.
If you have the right tools, the forum up on a computer, and a helper under an hour.
You will run into snags here and there. If your nuts and bolts are rusted and the such could take 2 hours. The nuts holding the rotors on are probably the biggest challenge, they were for me anyway.
I'm not sure what a Jag shop or any other shop would charge to do this job. I'll venture anywhere from 90-150 an hour, plus parts.
I ordered rotors, pads and calipers for $660. I paid my assistant lunch, coffee and a 12 year old bottle of 110 proof Wild Turkey Bourbon. I've got 9 hours into the job so far. I probably have 5-6 hours remaining.
If I have to do that job, I will bear that in mind, though I reckon that what you can do in 2 hours will take me a couple of days.
