Loose rad
Old Aug 13, 2017 | 02:26 AM
BC XJS's Avatar
Default Loose rad
I had my radiator rebuilt and after I installed it I noticed that it's loose on the top. Did I miss something. There are no mounting bolts.
Old Aug 13, 2017 | 04:27 AM
Greg in France's Avatar
There should be two huge rubber bungs that push-fit into the radtop panel, the holes in the middle of which go over the two prongs sticking up from the radiator. maybe these are missing?
Number 11 in this diagram. Two at the bottom and two at the top
Old Aug 13, 2017 | 06:59 AM
orangeblossom's Avatar
Hi BC
You can see one of the Rubber Bungs in this Photo, which fit into holes in the Top Closing Panel, that go over the Top Pegs on the Rad to hold it in place. (Just like Greg said)
On the Top Closing Panel is a Rubber Bung each end that go over the pegs in the Top of the Rad to hold it in place
Old Aug 13, 2017 | 12:38 PM
BC XJS's Avatar
Thank you for the quick response. My rad is missing those. Probably because mine has a sbc. I'll have to figure something out
