Loose Radiator - 1996 XJS Facelift
Old Mar 13, 2020 | 05:37 AM
  #41
Vee's Avatar
Vee
The new mounts I have, are OEM. I should have known better....always use metalastic rubber....
Old Mar 29, 2020 | 04:23 PM
  #42
Vee's Avatar
Vee
I wanted to come back and wrap up this thread.
It was indeed a motor mount that was shot. I replaced both mounts with OEM Metalastic mounts.
It was the drivers side mount. I replaced the passengers side first, thinking it would be the culprit. I was disappointed that it came out whole. I thought it was going to be something else, so you should have seen the thrill in my face when I moved on to the drivers side!
I’m sure this was a leftover result from when my car was stolen and damaged.
Old Mar 29, 2020 | 05:18 PM
  #43
carsnplanes's Avatar
Did you do the engine mount torque test as described earlier (in Drive with brakes on to see the which side lifted).
Old Mar 29, 2020 | 05:45 PM
  #44
Vee's Avatar
Vee
Yeah, I mentioned in Post 36 that I was able to get it to scrape in D, but not R. It wasn’t a lot, but I did hear it. Thanks for that bit of advice!
Old Mar 29, 2020 | 09:18 PM
  #45
Ah ok, sorry. Must have missed that reply.
ok, that makes sense then that the drivers(left) side mount would have picked up in "Drive"as it is trying to twist opposite to engine crank rotation. Glad you found it.
Old Mar 30, 2020 | 06:21 AM
  #46
ptjs1's Avatar
Vee,
Well done, glad you got it fixed. I'm guessing that rotation was causing the fan to scrape on the top of the shroud? If so, you might want to remove it now and inspect for any even slight stress cracks starting to appear on the blades as a result of the scraping. You dont want one those blades tio let go as a result of being even slightly weakened.
Paul
Old Mar 30, 2020 | 10:04 AM
  #47
Vee's Avatar
Vee
Thanks. The fan blades look fine. They are relatively new, since they were replaced when the car was stolen. I was thinking that same thing.
The car feels new again with the new shocks. I didn’t realize what a mess the Boge shocks were. I tossed them away, but I still have the original shocks from the car. While far from new, they feel quite serviceable still! I have Sachs on the car now. We’ll see how long they last. I bought them from a vendor that apparently warrants them for life!
Mac Allan
Jun 2, 2022 08:46 PM
Mike Beda
Oct 8, 2019 12:48 AM
bladerunner919
Nov 26, 2018 08:40 AM
newworld
Jul 22, 2017 07:05 PM
chrisc923
May 21, 2014 07:04 PM
