Is this my throttle kickdown switch? & 2 others
Old Jan 14, 2013 | 07:48 PM
Roland Gotzke's Avatar
Default Is this my throttle kickdown switch? & 2 others
Hi there,
I think my throttle kick down switch casing is broken and needs to be replaced. I also noticed the blue wired gizmo looks like it needs to be replaced as well. It's wires look a bit cooked. And... the third bit hangs just below the throttle assembly toward the back of the motor - has a couple loose ends - should I fret where to connect them to?What are they?
Attached Thumbnails Is this my throttle kickdown switch? & 2 others-image-2.jpg   Is this my throttle kickdown switch? & 2 others-image-3.jpg   Is this my throttle kickdown switch? & 2 others-image-1.jpg
Old Jan 14, 2013 | 07:53 PM
Doug's Avatar
#1 is the throttle actuated enrichment switch
#2 looks like the vacuum actuated enrichment switch. Is is to the right and slightly aft of the the throttle capstan? If so, that's what it is
#3 not sure. What are the numbers on the widget?
Old Jan 14, 2013 | 07:58 PM
#2 Yes it is..
So #1 controls fuel air mixture?
#2 controls?
#3 - I'm running out to the garage now to see...
Old Jan 14, 2013 | 08:05 PM
Eac 4100
Old Jan 14, 2013 | 09:10 PM
Doug's Avatar
Originally Posted by Roland Gotzke
#2 Yes it is..
#2 controls?
Both do the same job.....enrich the mixture about 10-13%..... but differently.
#1 is mechanically operated off the throttle capstan. #2 is vacuum operated. It's just a redundant arrangement.
Old Jan 14, 2013 | 09:13 PM
Doug's Avatar
Eac 4100
Parts catalog simply calls it a "Solenoid Valve". It is part of the complicated vacuum advance system. I can't remember the exact function
Old Jan 14, 2013 | 10:06 PM
Thanks for your help Doug. Now the search for the parts begins...
Aus V8S
Nov 13, 2015 11:01 AM
Bigvettefreak
Sep 29, 2015 04:13 PM
Johnken
Sep 22, 2015 03:53 PM
Lannyl81
Sep 19, 2015 08:07 PM
John Fox
Sep 19, 2015 07:56 PM
